Ashstarlet200 Posted January 23, 2013 Posted January 23, 2013 Right guys in need of your help.I have the ct9 turboDump valveRelocated air filterStainless steel manifoldDecat downpipe with screamer pipeFront mounted intercoolerAfter market exhaust systemTurbo timer Now going to get a ebc or a hks actuator....What boost can i run safely on the car with the mods i have and not needing anymore (am willing to buy a fcd if needed) dont want to blow engine or anything Cheers guys Quote
starletburkie Posted January 23, 2013 Posted January 23, 2013 well just a fcd will blow the engine on its own! youll need a fpr aswell as the fcd! just under fuel cut so 0.8bar you can run on current setup Quote
Ashstarlet200 Posted January 23, 2013 Author Posted January 23, 2013 Sound ill turn it up a little to 0.8 then cheers mate. And with a fcd and fpr what can I run on that setup? Quote
starletburkie Posted January 23, 2013 Posted January 23, 2013 1.0bar on the ct9, thats the fcd and fpr set up with wideband Quote
smobey_sutton2 Posted January 23, 2013 Posted January 23, 2013 If you run 0.8 mate you'll start hitting fuel cut now and again as it will creep. Go for management mate, stay away from fcd and fpr's! Quote
starletburkie Posted January 23, 2013 Posted January 23, 2013 i ran 0.85 on ct9 and never had an issuse with fuel cut Quote
Ashstarlet200 Posted January 23, 2013 Author Posted January 23, 2013 For now ill run 0.8 until I sort some management out. Whats best a hks actuator or a ebc? Quote
Snazzyblowfish Posted February 1, 2013 Posted February 1, 2013 Mines running 0.6 and hitting fuel cut. Fcd just makes it rev out at 3.5k and spit flames. Sounds wicked but cannot be good, have removed fcd and left it. Any ideas? Quote
Amjad Posted February 1, 2013 Posted February 1, 2013 Port the wastegates and run 0.8 bar, boost will hold a lot more stably Quote
