What's Up Guys A Question To All You Uk Starlet Owners What Do You Guys Know Or Think Of The "Haltech Sprint500" For A Glanza V?
All opinions are welcome
Good ecu, will do most things you want on a starlet. But tbh unless you plan on changing your ignition setup theres no need to swap over to a standalone unit unless you just want features like ALS, LC etc.
I run one good bit of kit for the money tuners really like them and they have great support also. The car drives so much better then it did with the e-manage ultimate having the 550's setup sequentially and using a liner tps is always gonna be a good thing then bad. They're not to hard to fit if you use a field harness and work with stock sensors also have a built in map sensor if you dont want to run a 3 bar one. You have a lot more options if you plan on upgrading mechanically in the future. Saying that though I'm not sure what kind of setup your planning on running?
Edited by Corey
