Mernagh Posted January 31, 2013 Posted January 31, 2013 well all has anyone the torque settings for a 1.2mm head gasket ?? Quote
Flaminsam Posted January 31, 2013 Posted January 31, 2013 I presume they will be the same as normal? Its only the torque for the headbolts. The gasket will still get sandwiched between the head and block as normal? Quote
Mernagh Posted January 31, 2013 Author Posted January 31, 2013 i was thinking that but im just making sure is all Quote
Idrees Posted February 1, 2013 Posted February 1, 2013 As above, it depends on your head bolts. The head gasket won't affect the torque settings. Quote
AdamB Posted February 1, 2013 Posted February 1, 2013 Depends on the method of securing the head. OEM Bolts:Stage 1 - 22 NmStage 2 - 44 NmStage 3 - 90 degrees Quote
