For sale: Megasquirt ms11 3.01 ecu, edis distributorless ignition and custom leads, trigger wheel, tps, loom and jimstim simulator (for mapping in your living room!)
Item Condition: all brilliant
Price and price conditions: £600 for full kit ready to run in an ep82
Extra Info: This is a fully mappable ecu, that is easily tuned and comes with all the installation you need to make a starlet run. As you can see the kit is comprehensive, and is all done to a great standard. The kit uses Ford edis, a very good ignition system that is wasted spark and distributorless, no worries about blowing out your spark at high rpm. The ecu hardware is great with an on board 3 bar map sensor and the ability to run launch control, antilag, harsh cut rev limiter at any rpm, 16x16 table mapping. Software can be bought for £20 which allows self tuning to a wideband lambda sensor. The ecu will come with a basemap loaded to get your starlet up and running. You literally wont have to buy anything else. The kit will be install and get mapping on a dyno or on the street. It even comes with a Jimstim engine simulator which allows you to hook up to a laptop and tune and modify settings in your ecu when it is not even connected into the car.
Ecu, leads and jimstim simulator
Edis module
Leads
edis coilpack
Trigger wheel
Contact Details:
PM
Delivery & Conditions of Delivery: delivery £10 to uk, europe can be quoted
