mini1.3 Posted February 5, 2013 Posted February 5, 2013 (edited) Found these browsing ebay Toyota Starlet Glanza 4E-FE 4E-FTE Alloy Alternator Pulley http://www.ebay.co.uk/itm/251224757012?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_nkw%3D251224757012%26_rdc%3D1 Toyota Starlet Glanza 4E-FE 4E-FTE Alloy Power Steering Pulley http://www.ebay.co.uk/itm/251224760722?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D251224760722%26_rdc%3D1 Might order a set as seems a trusted seller and they seem to do alot of lathe / CNC work Edited February 5, 2013 by mini1.3 Quote
mini1.3 Posted February 9, 2013 Author Posted February 9, 2013 Mine arrived yeterday i ordered without powdering coating so i could see the quality and no machining marks teeth arn't to sharp ( as others i purchased cut the belt ) all meaures up with my verniers and scales spot on im certainly going to buy some more for my project. hi yes they are producing the crank pulley as we speak got to test them and produce enough for demand group buy would be good for the set of 3 ????CheersThey can make all sorts of pulley and custom engine bits so might be worth knowing they rebuild engine tune engines welding body work painting welding so useful to noo Quote
rmsnoel Posted February 12, 2013 Posted February 12, 2013 Are they lighter or underdrive mini? Seems a waste to me man. How do u rate them now u have them, not quality wise but I performance wise I mean Quote
mini1.3 Posted February 14, 2013 Author Posted February 14, 2013 well it does not dip in revs when idling and having everything running and windows etc and and lights dont go dim when using the windows whilst driving so I give them a good rating soon as they have made a crank pulley ill order one and then I will notice more difrence as that will be alot lighter and will be using less energy to run everything Im that imprssed Ive rang and ordered another set for my project car and my mums ep91 na Quote
