Amjad Posted February 9, 2013 Posted February 9, 2013 I've recently picked up a HKS back box for my NA, which currently has a custom cat-back system. The HKS is flanged (2.5"/63mm) but just below the flange there is a slight step down in the pipe to approx 2.25"/57mm. The current back box is clamped on, and I'm pretty sure the piping is 2.5" Am I right in thinking I'd need a 2.5" flange and gasket, and a reducer sleeve as pictured below to fit it to my system? I'm guessing a 2.5" flange cant just be welded on to my mid section as there is a gap in the piping size? How would the sleeve be fitted? By way of a clamp or welding it in? Is there a better or easier way of fitting the box? Thanks Amjad Quote
A L 3 X Posted February 9, 2013 Posted February 9, 2013 How much difference is there between the flange pipe size and yours? You could probably get away with just welding it if its not too much Quote
Amjad Posted February 9, 2013 Author Posted February 9, 2013 I haven't been able to get under the car to check as it's raining at the moment! I'd have thought a 0.5" gap between the flange and pipe would be too much Quote
A L 3 X Posted February 9, 2013 Posted February 9, 2013 I remember in an old car I had mate I ordered a reducer to clamp on but the seller got mixed up with the sizes I wanted and it was wrong, took it to a mechanic I know and he tacked it together and then filled with weld, not the best solution but it worked, was only like. 0.5cm gap all the way around on mine though Quote
Amjad Posted February 9, 2013 Author Posted February 9, 2013 Hmm might work, but I don't wanna have to take the old box off match up and flange then to see I'll need a reducer, then have to order it and do it all again. Anyone else? Quote
james@cjperformance Posted February 9, 2013 Posted February 9, 2013 bring it up when your back and ill sort it for you Quote
Amjad Posted February 9, 2013 Author Posted February 9, 2013 To the rescue again haha Grant was gonna do it but I may as well wait for you because I need to clutch done too! Quote
