Removing wheel bearings from front hub
Im in the process of changing my wheel bearings on my project Glanza. Run into a bit of an issue the ball cages and inner race has dropped out leaving the outer race stuck. Should I just try and press it out with a really wide metal dolly or is there an easier way? I wouldve thought it would come out in one piece.
Also I take it that it'll only press out one way (the wheel side of the hub)
Any help appreciated! :)
Easiest way is to run a bead of weld round the inside of it, when it cools it contracts and pulls the race and its easier to get out. Just hit the bead with a punch and hammer and it should just drop out ;)
Finally got it a mate luckily had a set of metal plates for pressing bearings. Lined one up the same size and bang out it pops.
Welding would've been the next choice as that's what I do at work with bigger stuck bearings.
Cheers for the replies!
