slochyloon Posted February 9, 2013 Posted February 9, 2013 What is they best way to put them on? Stick? Or clip? Quote
mattyD Posted February 9, 2013 Posted February 9, 2013 bit of both mate, I used the clips and double sided foam tape works a treat Quote
slochyloon Posted February 10, 2013 Author Posted February 10, 2013 tidy where abouts could I get a hold of clips? Quote
Matts Posted February 10, 2013 Posted February 10, 2013 bit of both mate, I used the clips and double sided foam tape works a treat where did you get the foam tape from was it any specific brand? looking for some to go along side my clips Quote
Mel85 Posted February 19, 2013 Posted February 19, 2013 i'd guess 3M would do something man enough for the job. at the risk of thread hijacking - removing the stock wind deflectors as mine are broken, i'm guessing pop the clips then a heat gun to soften the adhesive? Quote
Idrees Posted February 19, 2013 Posted February 19, 2013 i'd guess 3M would do something man enough for the job. at the risk of thread hijacking - removing the stock wind deflectors as mine are broken, i'm guessing pop the clips then a heat gun to soften the adhesive?That might melt the deflector. Remove the clips then use a blade to cut the glue off. Quote
melon Posted February 19, 2013 Posted February 19, 2013 Has anyone seen any decent deflectors on the net for at 82? Need to replace mine that got broken Quote
