russ78 Posted February 14, 2013 Posted February 14, 2013 should hopefully have all parts for my forged build next week just wondering what assembly oil is recommended and what oil have people used ? Quote
AdamB Posted February 14, 2013 Posted February 14, 2013 Redline engine assembly lube, or torco. Some people prefer to just use normal engine oil as it can become a pain with the dilution of assembly lube and oil together. It depends how long you plan on "storing" the engine for. If its only going to be for a week or so, then use engine oil. Anything longer you would be best using an engine assembly lube. Quote
russ78 Posted February 14, 2013 Author Posted February 14, 2013 well my plan is get it built and get it run in asapcheers for the info Quote
Taggy Posted February 14, 2013 Posted February 14, 2013 I found engine oil a bit thin when i built mine, I bought some from demon tweeks on ebay, was about £8, its thick and doesn't run like oil ;) worth the ££££. Quote
russ78 Posted February 14, 2013 Author Posted February 14, 2013 no a bad price do you remember the brand ? Quote
