Keri-WMS Posted February 24, 2013 Posted February 24, 2013 I'm trying to get a handle on exactly which discs were fitted as standard to which EP8# and EP9# series cars, both UK and JDM. I think the pads change as well, so need that too! It seems like the EP7# and EP8# all use one type of pad, but the EP9# uses a different pad for all discs? Here's the "UK info" I have access to, but it MAY be wrong or have a bit of JDM in there too!!!! Anyone got more confirmed disc info and models to add? EP7#1.0 GL 85-89 N/A F = ?--------------------------------------------------------------------------------1.3i 84-89- 43512-10070 (226x16 54mm bore vented)--------------------------------------------------------------------------------1.5 D DL Diesel 86-89 = ? EP8#1.0 GL 89-96- 43512-10160 (229x16 55mm bore vented) F V.DISC (-ABS)- 43512-16070 (238x18 55mm bore vented) F V.DISC (+ABS)--------------------------------------------------------------------------------1.3 12V KAT 89-92- 43512-10160 (229x16 55mm bore vented) F V.DISC (-ABS)- 43512-16070 (238x18 55mm bore vented) F V.DISC (+ABS)--------------------------------------------------------------------------------1.3i GLi 92-96- 43512-10160 (229x16 55mm bore vented) F V.DISC (-ABS)- 43512-16070 (238x18 55mm bore vented) F V.DISC (+ABS)--------------------------------------------------------------------------------1.5 D Diesel STD 89-96- 43512-10070 (226x16 54mm bore vented) EP9#1.3i CD 96-99- 43512-10160 (229x16 55mm bore vented) F V.DISC (-ABS)- 43512-16070 (238x18 55mm bore vented) F V.DISC (+ABS)- 43512-16080 (254x18 55mm bore vented) F V.DISC (+ABS) <<< I take this one to be the Turbo/Glanza disc - WAS it on a UK 1.3i CD?! Quote
