Chrishoughton1989 Posted February 26, 2013 Posted February 26, 2013 Hello can this cause low oil pressure when cold and be fine when at running temp. Thanks. Quote
turbo Grant Posted February 26, 2013 Posted February 26, 2013 I'd say if the pressure relief valve was faulty it would do it all the time. It's just a plunger with a spring Quote
Chrishoughton1989 Posted February 26, 2013 Author Posted February 26, 2013 Are there any gaskets seals from pick up to block prone to cracking. ? Quote
turbo Grant Posted February 26, 2013 Posted February 26, 2013 Not that I know of. Seen the mesh strainer block up on loads of cars causing oil light to flicker on idle Quote
Chrishoughton1989 Posted February 26, 2013 Author Posted February 26, 2013 Could be that. Sump off weekend. Would be fine warm as well wouldn't it because oil thinner. Quote
