1990timeismoney Posted March 1, 2013 Posted March 1, 2013 hi i drove the car today and the clutch dosnt bite unless its nearly to the floor.it dosnt see to be slipping is there any way to adjust it or is there a comon reason for this to happen.any help much appreciated.luke Quote
StuDoc 72 Posted March 1, 2013 Posted March 1, 2013 If its biting near the floor then its biting too early? Not too late. If its biting high up then its too late and there is risk of slipping. Theres a rod on the pedal give that an adjustment and see if it helps. Also bleed your cylinder and see if that helps aswell. Quote
1990timeismoney Posted March 1, 2013 Author Posted March 1, 2013 ok thanks ill give that ago thanks for the reply what level should the fluid be al there is is a black plug inside the bottle Quote
AdamB Posted March 1, 2013 Posted March 1, 2013 Theres the clutch reservior on the firewall mate, just top this up. Quote
1990timeismoney Posted March 1, 2013 Author Posted March 1, 2013 Theres the clutch reservior on the firewall mate, just top this up. cheers mate will update tommoro and let ya no how it went Quote
