natalie_fuller Posted March 5, 2013 Posted March 5, 2013 Hi all Hope you can help, my GT is heasitaing after a run on the motoway, it sutters and then clears when i give it a bit more.i have replaced the injectors, fuel filter, plugs, leads, dizz and arm are good, vacum lines are good. pleased help its driving me crazy Quote
turbo Grant Posted March 5, 2013 Posted March 5, 2013 The ignition moduel and coil pack can give this problem Quote
natalie_fuller Posted March 5, 2013 Author Posted March 5, 2013 thanks bud, how would i test for this? Quote
DaveKidd Posted March 6, 2013 Posted March 6, 2013 If your leads and dizzy are good then most probably is one of the 2 as stated by turbo grant, i`d start by trying a second hand coil pack either borrow from a friend or see if someone will sort you cheap from the breakers yard. Quote
