Interesting car color choice aha..
But anyway, sweet! You know the vacuum line that comes off the top of the dumpvalve.. You can chuck a bolt in the end of it and cable tie it tight, you would have to in return get another bit of vacuum and block off where it goes onto the inlet manifold. So what i'd do there, if you don't have any spare vacuum is id cut a tad bit off the vacuum used for the dump valve and then block it up the same with a bolt and cable tie to put on your inlet.
Does that make sense? If not i will 'attempt' to draw a picture lol.
edit - reading back on that, it is quite complicated.. i'll draw a picture for you lol.
So the vacuum pipe that goes from dump valve to inlet manifold need chopped and blocked up? Surely thatd give me turbo chatter?
Edited by RossTRD
Yeah, it will.. I thought that's what you wanted lol? Well you either have a dump valve noise or chatter. Or unless you have a bog standard oem bov which makes no noise then yeah, you either have chatter or bov noise.
This is what i meant anyway;
I got hybrid turbo and ssqv and get chatter like crazy at low revs and bov noise when booting i. Got ssqv as tight as it'll go on adjuster with lock nut removed
