Chrishoughton1989 Posted March 10, 2013 Posted March 10, 2013 Is this a direct replacement ? I mean the actual turbos are they similar? Thanks. Quote
jordan walker Posted March 10, 2013 Posted March 10, 2013 If you mean a straight swap for a ct9 then no you need a different manifold and a different decat Quote
Chrishoughton1989 Posted March 10, 2013 Author Posted March 10, 2013 Mine has a different manifold and de cat but still has the ct9 will the tdo4 mount these ? Quote
maddox710 Posted March 10, 2013 Posted March 10, 2013 No that will just be an aftermarket manifold for ct9 only. Ct9 is a little square flange and td04 has a triangular shaped flange on the manifold. There is no direct replacent turbo that dont involes rotating the compressor housing and changing intercooler pipeing Quote
