i have been offered a set of oz f1 wheels from a phase 1 172, does anyone know if these will fit? i know they are 15x7 4x100 but cant find any info on the offset and the center bore.
any pictures would also be much appreciated
cheers
Steve
They are the correct PCD - the offset (et) will be stamped into the back of the wheel, although Google says they are between 35-42, which should go on out without any issues. Apparently their centre bore is 60.1 and I think the Starlet is 54.1, so you'll need some spigot rings, but these are very cheap on eBay.
i was worried the center bore was going to be too small. big is good as you say, spigot rings can fit that. i will have to try test fit one before i commit :)
  • 2 months later...
