Hi I'm helping a mate restore a bedford cf camper
We're getting cracked on bit I cannot work out why his indicators will only light up and not flasher
It's had a brand new flasher can and still the same
He has after market rear clusters and I'm not 100% on working out the correct watts these should be
As I'm writing this more ideas are popping in to my head on why but all input is grately recieved
Thanks team
Edited by yaristurbo
You just using a 2 pin flasher relay? Make sure you have power going to it from ignition supply would t have thought the watts should be an issue really. Should be 21w in there
Yes power and earth to it, think its 2x25w which I'm thinking it will need 50w or more to draw the correct current to operate??? Or am I thinking too much ?
You could test it with side light bulbs first if you want. But does sound like you need to get a 50w relay for it. Pretty basic the indicator relays with 2 pins. Not a lot you can get wroung
