Ok I got these from eBay, made a how to on fitment of them!
Before
1. Give the top of the window rubber a wee clean just with water and dry it. This is so that there is no bits of dirt in the way and so it is clean behind them!
2. Peel off the 2 sided tape on the end of the wind deflector!
3. Insert the wind deflector at the base at the wing Mirror side in where the window goâ??s in (window has to be down!!!) , push them right in!
4. As you go along the wind deflector pushing it in to where the window goâ??s in to you will note that it is to long and will over lap a bit
5. you need to then bend it out not to much or you will stress the plastic or snap it!! Then when you bend it out you can get the end in at the same time holding the 1st bit in. then just push the whole thing up in to place and that should be you
Donâ??t look too bad at all
after
