Arnold Posted April 15, 2013 Posted April 15, 2013 Hi all I'm about to change my brakes for new disks/pads, and just wondering how much fluid i'll need? I've got a 500ml bottle if that's enough? CheersArnold Quote
smobey_sutton2 Posted April 29, 2013 Posted April 29, 2013 You won't need any fluid if your only changing discs and pads mate Quote
*Zoe* Posted April 29, 2013 Posted April 29, 2013 Say your changing lines as well (as I will be doing next week hopefully) would 500ml be enough ? Quote
smobey_sutton2 Posted April 29, 2013 Posted April 29, 2013 Yeah should definately be enough. To do a whole brake fluid change I would usually use just under 1 litre. Quote
rob_bower Posted April 29, 2013 Posted April 29, 2013 Have a 1L to be safe. Just changed my rear beam and swapped to braided lines and changed fluid to 5.1 and used circa 750mlInfact have a spare 5.1 zoe if you need some can have it at what it cost me. Quote
Arnold Posted April 30, 2013 Author Posted April 30, 2013 You won't need any fluid if your only changing discs and pads mate Ah balls, of course! Cheers. I remembered last time I changed the brakes / lines and bought fluid for that, but that's already done. Quote
*Zoe* Posted April 30, 2013 Posted April 30, 2013 Have a 1L to be safe. Just changed my rear beam and swapped to braided lines and changed fluid to 5.1 and used circa 750mlInfact have a spare 5.1 zoe if you need some can have it at what it cost me. i'll Pm you about that Thanks for advice Quote
mech5107 Posted April 30, 2013 Posted April 30, 2013 I changed the master cylinder and bleed all the corners with just a bottle of ATE superblue. Quote
