if i had a wish i would ask god to fix my glanza ;-)
Gutted,
Waited 6 months for my car, will have spend nearly 7k on mods and have just found out there could be a problem with the engine 6 months in.
crank case pressure is much higher than it should be.
it made a measly 290 bhp at 1 bar, on the v band kit, which is rated to 400 bhp.
The engine made 335bhp at 1.5 bar previously and this wasn't running right.
If the engine is screwed then i will need a company that can sort it out.
Can any of you recommend a company?
Thank you, im gonna go down the pub and cry into my beer ;-(
yeah it is at the moment, trying to work the problem.
just dissapointed that the car is geared to run the power and it looks like the engine will let it down.
im not a mechanic but would have thought the engine would be checked prior to going for big power.
Who built the engine? Whats the spec? If the crank case pressure is high then theres a problem with sealing in the cylinders for sure, wasting power away there.
Edited by AdamB
Yeah your right, we pushed to 330 bhp and it was smoking, so I've decided to have a full re build, it's more money but at least it will be a fresh job and to be fair when you buy a car you never really know what state it is in.
