stup86 Posted August 28, 2007 Share Posted August 28, 2007 Morning,As far as I'm aware, for a TD04 conversion you need the following:TD04 TurboManifoldDownpipeRadiatorextended oil lines for turboHave I missed anything out?Also does anyone know if the downpipes from WEPR will fit to the standard exhaust???TaStu Quote Link to post Share on other sites
Hodgy Posted August 28, 2007 Share Posted August 28, 2007 Morning,As far as I'm aware, for a TD04 conversion you need the following:TDO4 TurboManifoldDownpipeRadiatorextended oil lines for turboHave I missed anything out?Also does anyone know if the downpipes from WEPR will fit to the standard exhaust???TaStufmic, fueling Quote Link to post Share on other sites
Guest Enzo Posted August 28, 2007 Share Posted August 28, 2007 injectors also Quote Link to post Share on other sites
stup86 Posted August 29, 2007 Author Share Posted August 29, 2007 So there's nothing that i need purely to do the conversion? I'll have a FMIC and bigger injectors by the time I do the conversion so that won't be an issue.Cheers for your replies guys,Stu Quote Link to post Share on other sites
Guest Enzo Posted August 29, 2007 Share Posted August 29, 2007 dependant on kit ul need a civic raidiater aswell i would imagine Quote Link to post Share on other sites
Hodgy Posted August 30, 2007 Share Posted August 30, 2007 and it obviously all set up Quote Link to post Share on other sites
carter Posted October 19, 2008 Share Posted October 19, 2008 the wepr kit will fit with the standard rad. i know this as i am using the standard rad. it would help with a civic rad as it would be easyer to fit and get to but you really dont need it. and yes the wepr down pipe fit perfect to the exhaust i had no problem with it lined up straight away.and it obviously all set up Quote Link to post Share on other sites
