Ep91kez Posted April 25, 2013 Posted April 25, 2013 Bottom end went in my auto glanza. Got the bottom end sorted and put it all back together. tried turning the car over and the starter is just clicking and not spinning the engine. Getting fed up with it now someone please help cheers in advance Quote
jtaylor1990 Posted April 25, 2013 Posted April 25, 2013 I know its probably the first thing you did but have you checked the battery? Sounds like a flat battery to me Quote
Ep91kez Posted April 25, 2013 Author Posted April 25, 2013 i thought that so got jump leads on it for about 15mins and tested it with a voltage tester got 12v =\ Quote
TurboTobz Posted April 25, 2013 Posted April 25, 2013 Did you crank it by hand before putting the lump in? Quote
Ep91kez Posted April 25, 2013 Author Posted April 25, 2013 Yeah turned over fine. Got the box on and it wouldn't turn then but thought it was because it was taken out while it was in park Quote
Starbo Moorley Posted April 25, 2013 Posted April 25, 2013 Sure its not stuck in drive or sonmert daft ? Tried giving the starter a whack too make sure it aint stuck lol Quote
Ep91kez Posted April 25, 2013 Author Posted April 25, 2013 yeah gave the starter a good tap and it doesnt seem to of done anything. cant see how it could be in drive it came out in park and the box hasnt really been touched since. maybe its something to do with the starter but dont know why it would click if it wasnt trying to turn Quote
AdamB Posted April 26, 2013 Posted April 26, 2013 Are you sure the earth strap is on the starter? I've seen some where they come off. Quote
Ep91kez Posted April 26, 2013 Author Posted April 26, 2013 Not 100% but will check tonight cheers =] Quote
