- stripped thread fixing panhard - emergency [ to me :-( ]
HI all
Well I've been a wally, I replaced my panhard bar yesterday as drivers side was scrubbing. I swear I only tightened the flange nut holding the whiteline bar at the axle end by hand, But it didnt feel tight so i gave it a couple more pushes. I then decided to locktite it and removed it again but it had stripped the thread completely for the 1st 1/4 inch. The nut now only bites for about the last 1/8th inch. Arghhh these 5 minute jobs.
What should i do? leave it with only a bit of bite on thread, araldite it? I dont have tap and die and you couldn't get to it anyway, i think its 13mm stud would a 12mm draper hex die cut a new thread then use a 12mm flange nut, they say they are only for chasing bolts not rethreading.
And all on a bank hol weekend when everywhere is closed until monday :-(
advise much appreciated
Ric
Edited by ric
You could try running a chaser down the tread. And you could try putting the nut on and drilling throw the when its on and put a roll pin in for good measure
hi, thanks for reply,
theres no part of stud end visible ie doesnt go past end of nut so cant put a pin after nut. I have a 12mm chaser on order, it was a 13 thread and flange nut. ive hand tightened it for now and taken it for a good drive over bumps etc and it hasnt moved so maybe buying a new 13mm nut and some araldite would work, i'm no mechanic so recutting it worries me. i guess i could just pop into quikfit and let them put a smaller bolt on.
ric
well i've driven it around today and the nut doesnt appear to have moved, but i didnt locktite it, should i take it of yet again and return it with locktite or jb weld or just leave it alone?
I dont think the nut is under much strain, it appears to hold the large washer against the bush and sleeve on the stud, I think all stress is on the stud in an up down motion not the nut and washer.
ric
  • 2 weeks later...
Wll i bought a die set to recut a thread but hey it appears the nut is an oem size, and the stab is probably hardened steel, not sure what to do next
anyone know the nut size 94184-61200 a 12mm 1.75 appears to small, the die's above 12mm are getting rather expensive
maybe j b weld is the answer!
Ric
