Alright peeps
Start cold or hot
Dosnt smoke at all
Driving casually no smoke
Apply a bit of boost tiny bit of blue smoke but have all my boost
Standing on the spot rev high no smoke soon as it hose to idle puff of blue smoke but then alright ???
I had my head gasket and valve stem seals and valve springs shims cams done port polish all replaced I had my piston rings checked all good :/
About 1k ago
I brought a new hybrid turbo about 3k miles ago could it be the seals ????
Any clues ?
Blue smoke is either going to be coming from Rings, Turbo, valve stem seals or the PCV valve, make sure you have no oil in the intercooler pipes
Disconnect the PCV valve from the intake and block it off on the intake manifold, see if that makes a difference
Edited by Taggy
Kk fella if I was to look at intercollegiate pipes am I lookin for thick oil or a dust like on the inside ,l??
Also eats a little bit of oil my be turbo :/ ??
