redline Posted May 18, 2013 Share Posted May 18, 2013 Guys got a noise coming from the engine bay area when I put the clutch down it goes away? Somtimes when I put the clutch down and back up its gone? Just to add clutchs just been replaced and the noise wasn't there before the clutch was replaced any ideas? Thanks Quote Link to post Share on other sites
Idrees Posted May 18, 2013 Share Posted May 18, 2013 What clutch are you using? Was it fully inspected before fitting (even if it was brand new)? I assume the clutch release bearing was replaced too? Quote Link to post Share on other sites
redline Posted May 18, 2013 Author Share Posted May 18, 2013 (edited) Spec 6 puk paddle clutch? Brand new, and am not sure about the release bearing as I didn't fit it Edited May 18, 2013 by redline Quote Link to post Share on other sites
Glanza Mac Posted May 18, 2013 Share Posted May 18, 2013 Release bearing, mine does it too mate.. It will fail at some point Rob. Quote Link to post Share on other sites
redline Posted May 18, 2013 Author Share Posted May 18, 2013 On 5/18/2013 at 1:14 PM, Glanza Mac said: Release bearing, mine does it too mate.. It will fail at some point Rob.But mine was replaced ? I assume it was replaced with the clutch kit Quote Link to post Share on other sites
morgey Posted May 18, 2013 Share Posted May 18, 2013 Mine rattled days after being replaced. Only other thing it could be is primary shaft bearings. Inside thw box Quote Link to post Share on other sites
redline Posted May 18, 2013 Author Share Posted May 18, 2013 On 5/18/2013 at 3:52 PM, morgey said: Mine rattled days after being replaced. Only other thing it could be is primary shaft bearings. Inside thw boxMine was fine before the clutch was replaced tho Quote Link to post Share on other sites
morgey Posted May 18, 2013 Share Posted May 18, 2013 Is it a sprung clutch? Or solid, could be the springs rattling?Either way, doubt its much to worry about! Quote Link to post Share on other sites
redline Posted May 18, 2013 Author Share Posted May 18, 2013 It's a spec 6 paddle clutch mate, I dont think there suppose to rattle Quote Link to post Share on other sites
morgey Posted May 18, 2013 Share Posted May 18, 2013 Have you heard some heavy duty clutches, some sound crazy rattley hahaIf you are that concerned get the box pulled back off and check it out.Its just an upgraded stock replacement yeah? Not a full fly, clutch, pressure plate and bearing kit like the mental multiplate ones? Quote Link to post Share on other sites
redline Posted May 18, 2013 Author Share Posted May 18, 2013 It's a proper spec clutch think it's rated to abt 300 bhp it's a full clutch kit, stock fly wheel Quote Link to post Share on other sites
