where have people using Depo racing oil temp gauges, installed the sender on the engine??
im currently re doing my oil cooler kit, so need to fit this asap whilst oil cooler is being redone..
and im not to keen in fitting sender into sandwich plate, which is a mocal thermostatic one.
I've got mine in my sandwich plate... Don't think there are many other options really, could have the sump off weld a nut internally but will need to be low so when the oil surges you don't uncover the sender... Apart from that no where really
I use a sandwich plate too. Planning to run an oil cooler too but with an in-line thermo rather than a thermostatic plate
