McGlinchey Posted May 25, 2013 Share Posted May 25, 2013 Startled my car yesterday and the oil pressure gauge is flashing non stop, the gauge is a depo gauge.. All wired up correctly.. Engine is a 5e forged and hasn't even been run in yet, new oil pump etc.. Any one know what it could be? Quote Link to post Share on other sites
Burny Posted May 25, 2013 Share Posted May 25, 2013 What is the oil pump reading? Quote Link to post Share on other sites
Azz Posted May 25, 2013 Share Posted May 25, 2013 Usually when they flash its a warning for low pressure Quote Link to post Share on other sites
McGlinchey Posted May 25, 2013 Author Share Posted May 25, 2013 What is the oil pump reading?Sits at zero as If the gauge isn't actual working, but it's lit up Quote Link to post Share on other sites
Amjad Posted May 25, 2013 Share Posted May 25, 2013 I got this when the sensor plug was loose (Depo) Quote Link to post Share on other sites
Burny Posted May 25, 2013 Share Posted May 25, 2013 If its at zero then the light will come on, mine is set to come on if if it drops below 1.5. If its reading zero and the gauge is working properly you've got problems Quote Link to post Share on other sites
McGlinchey Posted May 25, 2013 Author Share Posted May 25, 2013 Oil light on the dash isn't on tho? Quote Link to post Share on other sites
McGlinchey Posted May 25, 2013 Author Share Posted May 25, 2013 I got this when the sensor plug was loose (Depo) My sensor plug is kinda broken (dosnt fit to well) could that be the problem? Quote Link to post Share on other sites
Amjad Posted May 25, 2013 Share Posted May 25, 2013 Sounds like it Quote Link to post Share on other sites
