Banbury Glanza Posted May 26, 2013 Posted May 26, 2013 My car isn't making full boost atm it's forged td04 and should be making 1.4 bar, I had a crack I'm my mani and thought that was why so got a new mani and de-cat and fitted it, which helped the spool loads. But I'm only getting between 1-1.2 bar now. Any ideas ?? Cheers Todd Quote
Banbury Glanza Posted May 26, 2013 Author Posted May 26, 2013 Will double check them all tomorrow bud cheers Quote
Weyro Posted May 26, 2013 Posted May 26, 2013 did you touch the actuator when you swapped the new mani and de-cat on? Quote
Banbury Glanza Posted May 26, 2013 Author Posted May 26, 2013 Might have done mate a friend done it for me Quote
Weyro Posted May 26, 2013 Posted May 26, 2013 do you have another other form of boost control? electronic or manual? if not you need to make the actuator arm shorter, do it half a turn at a time till you get the desired boost Quote
Banbury Glanza Posted May 26, 2013 Author Posted May 26, 2013 Yea I have a blitz ebc mate it was set up by tuning developments when it was mapped Quote
Weyro Posted May 26, 2013 Posted May 26, 2013 Ok cool, well you can either reprogram its settings, or adjust the actuator arm.Good idea to check for boost leak first though Quote
Banbury Glanza Posted May 27, 2013 Author Posted May 27, 2013 Ok mate I will do, if there's no leak why would it have just dropped ?? Quote
Weyro Posted May 27, 2013 Posted May 27, 2013 (edited) Only things i can think of, if its not a leak, is that the actuator was messed with when changing the Mani etc, or the actuator is a bit worn Edited May 27, 2013 by Weyro Quote
