Right my dad is dead set on raising my suspension because he rekons its to stiff and thinks that will soften it up a bit :p
Is he right???
Please say no because I want it lower at the back if possible and theres no way im raising it :p
Shall I just tell him that its the springs I need to change to softer ones???
Help is appreciated :p
if you want to pull the wool over his eyes you could say that he would need to invest in new springs as the current spring rates are too high,
he might not buy that though . .
Its called 'pre-loading the springs' Lewis, so the lower you adjust the cogs, the less rebound/room there is for the springs to make, making for an even harder and harsher ride, perfect for track use tho.
My front coilys are maxed (tanabes dont go all the way down), and my rear are down to the arches with still a lil' room for adjustment.
Also enzo mentioned to me once that there is a stage of lowering where you won't get any more gains, so after that it will be pure cosmetics not aesthetics.
Hope this helps.
Joz
Guest daveburwash
D2's are height adjustable without preloading the springs :p
