mikey4410 Posted May 28, 2013 Posted May 28, 2013 need to order up a few bits and cant get to the car for a few days. can anybody tell me the standard turbo inlet manifold diameter and also the diameter of the ct9 ilet feed piece thats between the top mount and ct9 inlet. would be great if somebody could find out,thanks Quote
StuDoc 72 Posted May 28, 2013 Posted May 28, 2013 Your description of the diameters you need makes no sense mate youll need to be more specific. Quote
mikey4410 Posted May 28, 2013 Author Posted May 28, 2013 sorry about that, i need the outer diameter of the throttle body on the 4e-fte i need the outer diameter of the the wide end of the piece between the top mount and ct9 thats almost a y shape,the piece were you would fit a dump valve. Quote
StuDoc 72 Posted May 28, 2013 Posted May 28, 2013 I think the diameter on the throttle body is 60mm although someone may want to correct me as that is almost a guess it just lingers in there as a figure. You need to kno the diameter of the hot pipe coming off the turbo? As in the diameter of the steel part? Quote
mikey4410 Posted May 28, 2013 Author Posted May 28, 2013 yea the pipe that bolts with to bolts to the ct9.i needd to know the top wide end diameter. thanks so much Quote
StuDoc 72 Posted May 28, 2013 Posted May 28, 2013 Im not 100% sure buddy but to find out the 2 diameters you need all you need to do is remove the top mount and youll be able to measure both and the top mount is a doddle to remove. Might be worth doing to be exact. Quote
