Is there not a how 2 guide on fitting a fimic I've looked through the how 2s and tutorials can't find one sware I saw one before ?
If not can anyone help me
Thanks
I'm not sure if there was.
Its not really difficult tbh I did it yesterday. Its worth getting a friend to help as 4 hands are always better than 2 but by no means is it impossible to do yourself.
What FMIC is it? And what starlet an 82 or 91?
It' should fit in theory came off an 82 was just wondering if anyone had any kind of tutorial on it that's all or any dos or donts ?
If it did then im sure you will be fine.
Few tips would be to remove the support bar wen your fitting it.
Mount the core on position and work around it. dont tighten everything right up until its all on.
Also give the pipes a quick polish before you fit them if they are dirty just so you know they are getting a clean seal.
You can also use hairspray in the joiners to be sure.
Other than that its very straight forward.
Ok thanks for that one more thing any info on bolt size that ill need to fix it on not sure if its coming with any
Thanks for info
