Bertie Posted June 5, 2013 Posted June 5, 2013 All I am thinking of installing a water /meth kit on my starlet - the motor is forged with CP pistons, Scat H-beam rods, Arp bolts, MSL head gasket, 370 cc Injectors. Running a Borgwarmer KKK 14 turbo, front maint intercooler and fuel pressure regulator. Any one done this before? Main reason for doing this is for the benefit of running higher boost and lower intake temperature. I also heard you an also increase timing with such system. Looking forward to your comments. Bertie Quote
Taggy Posted June 5, 2013 Posted June 5, 2013 first time i have heard of it but sounds interesting http://www.aemelectronics.com/water-methanol-injection-kits-23/ Wouldnt bother though unless you were going insane power though! Quote
AdamB Posted June 5, 2013 Posted June 5, 2013 What engine management are you using? You will need a programmable unit. There are gains to be had no matter what your power level as it reduces the chance of knock, ideal for those with higher air temps or poor fuel quality. Quote
Bertie Posted June 5, 2013 Author Posted June 5, 2013 Its a much safe way of boosting higher .... Suppose also depends on your hight above sea level. All our drag racing cars in Namibia has that installed..Check this video... http://www.turbomirage.com/water-alcohol-injection-videos.html Quote
Bertie Posted June 5, 2013 Author Posted June 5, 2013 My plan is to install either a Unichip on the standard computer or fully stand alone Dictator. Quote
starletgt-shady Posted June 5, 2013 Posted June 5, 2013 I will be installing mine in the next few weeks. I have a aquamist kit. Quote
Bertie Posted June 6, 2013 Author Posted June 6, 2013 Great we can then exchange information ... Quote
starletgt-shady Posted June 6, 2013 Posted June 6, 2013 Aquamist kits come with the own processor and depending which kit you get can run of injector duty cycle or boost pressure. My kit should be arriving tomorrow and has everything apart from a tank. My mate uses the kit in his mr2 and makes loads of difference and also keeping your intake temps down. He has a standard 3sgte engine with bigger turbo and made 294whp on Monday just past. Would of made more but maxed out standard injectors. Quote
Flaminsam Posted June 6, 2013 Posted June 6, 2013 im also interested in this idea. Saves getting the engine too hot under load and prevents det. Quote
