Its rear mount and drive shafts and lsd box out of a ep82 going into a not lsd glanza but i have abs would this be a problem
I would be thinking so yes for mot purposes as your front abs sensors on the hubs will be wanting to get a reading off the abs ring on the drives, which you won't have on the 82 drives.
Unless you want to put your 91 cv joints on the 82 shafts which would work fine also :)
Problem solved.
Edited by Sheehy StarletGT
