Licari3 Posted June 10, 2013 Share Posted June 10, 2013 What does a limited slip differential exactly in a car ? And why do people swap the stock differential with a lsd Quote Link to post Share on other sites
StuDoc 72 Posted June 10, 2013 Share Posted June 10, 2013 (edited) Exactly what it says on the tin. Limits the amount of slip. If you were to jack up 1 of your front wheels and have a non lsd put it in gear bring up the clutch and gun it. Only the wheel which is jacked up will turn and the car should stay still.An lsd basically prevents this from happenng to allow better traction if 1 wheel was to lose contact with the ground.Thats it put simply. Edited June 10, 2013 by StuDoc 72 Quote Link to post Share on other sites
