mikey4410 Posted June 13, 2013 Posted June 13, 2013 i have ample oil in car,car runs fine and been driving for hours today,do i need a new oil pressure sensor im guessing weres it located ? Quote
steve-gers Posted June 13, 2013 Posted June 13, 2013 Front of engine behind the downpipe just under manifold. Quote
mikey4410 Posted June 13, 2013 Author Posted June 13, 2013 thanks for the rapid reply buddy !! top man. will an n/a one work on a turbo ok im guessing as its same block ? Quote
EliteMilk Posted June 14, 2013 Posted June 14, 2013 Will screw in but I'm not sure if the plug is the same Quote
mikey4410 Posted June 14, 2013 Author Posted June 14, 2013 this is sorted guys,the spade connector that goes on the oil pressure switch was on one of the water housing sensors. Quote
