Drivin home tonight and doin bit of fooling about and the speedo stuck an car stuck in gear. Then when i got it out of gear was really hard to change in to any ger? Had to use force? anyone no what this could be? Cheers
Yes mate :)
Best bet is to get someone to push the clutch pedal and then look around the gearbox area and look to see if the cables are moving at all (2 of them).
