Rock-Kick-Ass Posted June 14, 2013 Posted June 14, 2013 lads i need your advice on this.. recently i took the plastic cover off the speed clocks to give them a clean as they looked dirty.. anyway before i went and did this the petrol needle was below the empty mark with the flashing empty warning sign showing up.. so i cleaned them and touched the needle.. now the needle is at the quarter mark and wont go back down to the empty place were it should have been.. so it at that mark and the low petrol sign shows up.. do you know wat could have cause this apart from me cleaning them http://s1154.photobucket.com/user/dazman2/media/Photo-0005-2.jpg.html'> Quote
turbo Grant Posted June 14, 2013 Posted June 14, 2013 (edited) Move it back down and fill up see what happensEdit; because on toyota gauges the fuel needle stays in the same place when you turn the key off Edited June 14, 2013 by turbo Grant Quote
Rock-Kick-Ass Posted June 14, 2013 Author Posted June 14, 2013 Move it back down and fill up see what happensEdit; because on toyota gauges the fuel needle stays in the same place when you turn the key off il try that but i dont think it will work as i out in €20 the other day and it still wont go down..but i didn hold down the needle.. so il give it a go and see what happens Quote
