TurboTobz Posted June 20, 2013 Posted June 20, 2013 (edited) Item for sale: Blitz Super Sound Blow off valveItem Condition & Description: A polish and this will look as new, can be welded onto intercooler pipework, or hosed on. These were around £250 when TMD were selling them!Price:£80?Pictures: Payment & Shipping Details: +4% paypal Postals £4. Item For Sale: Blue anodised Throttle pulleyItem Condition & Description: VGC, came over on the car from Japland I think.Price: £20? Will need your standard pulley in return, I use my car daily so I will need yours to arrive before I remove mine.Pictures: Payment & Shipping Details: +4% Paypal and Postal £free. Item For Sale: JPerformance catch can.Item Condition & Description: Catches oily residue and tidys the bay.Price: £20?Pictures: Payment & Shipping Details: +4% Paypal and Postal £4. Item For Sale: Rspec Turbo TimerItem Condition & Description: JDM turbo timer, all works. It has no harness but it can easily be wired in without it, I can mark the wires for you before I remove it. It can also calculate run down times via rpm wire. Has a stopwatch and handbrake cut out.Price: £20?Pictures: Payment & Shipping Details: +4% Paypal and Postal £3. Item For Sale: Screamer pipe.Item Condition & Description: Be the envy of your neighbours with this antisocial piece of artwork. Stainless steel.Price:£20?Pictures: Payment & Shipping Details: +4% Paypal and Postal £4 Item For Sale:Wepr Evo Td04/5/VF series stainless manifold.Item Condition & Description: Hanging, it has had some repairs over time, will need some slight repairs including a small crack on runner 1, and there seems to be a blob of weld on the turbo flange which could do with being ground flat. Its had the external waste gate port removed and blocked to run actuator set up but I will include a wastegate port (38mm) for £5 extra that can be welded back on.Price: £65?Pictures: Payment & Shipping Details: +4% Paypal and Postal £15 Item For Sale: Smoked Boost gaugeItem Condition & Description: Shows boost and vacuum looks pretty.Price: £20?Pictures: Payment & Shipping Details: +4% Paypal and Postal £4 Item For Sale: PLX DM6 Multi gauge and Wideband module + bosch sensorItem Condition & Description: No calibration needed, has peaks and warns, can be linked to up to six other modules and display them all on one gauge, it graphs your afrs and shows them aswell on the led outer ring. Packed with features under 10 hours use Id say and IMO far superior to the AEM units.Check these links.http://www.plxdevices.com/product_info.php?id=WDBDSMAFR_DM6 Overview:The PLX Wideband AFR (UEGO) gauge combo combines an accurate, fast response wideband AFR (Air Fuel Ratio) controller with the world's most advanced touch screen 2 1/16" gauge (52mm). It includes a Bosch LSU4.2 wideband oxygen sensor. The wideband controller (SM-AFR) works with gasoline, bio diesel, ethanol, methanol, E85, LPG, and CNG. It includes two analog outputs (wideband 0-5V, and narrowband 0-1V) for interfacing with 3rd party devices and one digital serial output for interfacing with the DM-6 gauge and other Multi Gauges. The wideband analog output is ideal for interfacing with aftermarket ECU's and data loggers. The narrowband output is ideal for stock narrowband oxygen sensor replacement where the simulated narrowband analog output is fed back into your ECU to make it operate as if the stock narrowband oxygen sensor is still installed while running the PLX wideband setup. All three outputs can be used simultaneously. Additional features include advanced soft start technology which prolongs the oxygen sensor's life and an aluminum enclosure for durability and reliability.Features:Plug and play controller and gauge comboNo Calibration RequiredSoft start technology2 analog outputs1 digital input, 1 digital outputBosch LSU 4.2 SensorCompatible with multiple fuelPrice:£150?Pictures: Payment & Shipping Details: +4% Paypal and Postal £5. Item For Sale:Genuine HKS mushroom filter.Item Condition & Description: Filters the air your blower compresses.Price: £45?Pictures: Payment & Shipping Details: +4% Paypal and Postal £4. Item For Sale: Optional Extra Wind deflectorsItem Condition & Description: Good condition.Price: £55?Pictures: Payment & Shipping Details: +4% Paypal and Postal £8. Item For Sale: Optional Extra Ignition barrel light.Item Condition & Description: A light up ring! Will require a new fuse but it is tested and working.Price:£40?Pictures: Payment & Shipping Details: +4% Paypal and Postal £4 Item For Sale: Razo PedalsItem Condition & Description: see pics, came on car from JDM afaik.Price: £10 posted.Pictures: Payment & Shipping Details: +4% Paypal and Postal £free. Item For Sale: 4EFTE Pauter Forged Con rods with ARP 2000 bolts.Item Condition & Description: One rod is bent this costs something like $147 from Pauter USA I have all the details required in emails from pauter that I will pass on to the buyer. Other than that very good condition best off the shelf rods and afaik the only ones that dont require your block to be notched.Price: Offers?Pictures: Payment & Shipping Details: +4% Paypal and Postal £8. Item For Sale:Wiseco 74.5mm Forged pistons.Item Condition & Description: Best off the shelf pistons, one oil ring is damaged and two of the pistons have markings to the underside.Price:Offers?Pictures: Payment & Shipping Details: +4% Paypal and Postal £5. Item For Sale: CT9 Oil returnItem Condition & Description: Feels good, worked fine, comes with both clamps.Price: £10Pictures: Payment & Shipping Details: +4% Paypal and Postal £2 Item For Sale: Distributor assembly and Denso Rotor.Item Condition & Description: Very good condition.Price: £25Pictures: Payment & Shipping Details: +4% Paypal and Postal £8. Item For Sale: Cam gear.Item Condition & Description: Spins around! Vgc.Price: £10?Pictures: Payment & Shipping Details: +4% Paypal and Postal £3. Item For Sale: Iridium NGK racing Spark plugsItem Condition & Description: Good conditions are used be not for long, just for you cheap skates.Price: £10Pictures: Payment & Shipping Details: +4% Paypal and Postal £3 Item For Sale: Thermostat housing and sensors.Item Condition & Description: Does what it says on the tin, has no thermo but could include one.Price: Offers?Pictures: Payment & Shipping Details: +4% Paypal and Postal £8 Item For Sale: 98 Spec bumperItem Condition & Description: Has been cut out for fmic, side exit exhaust and a small cut out below the right hand side fog for an intercooler pipe that fouled. Could do with running over with a DA and repainting.Price: £20Pictures: Payment & Shipping Details: +4% Paypal and Postal pickup preferred but will post. Item For Sale: 4efte CamshaftsItem Condition & Description: good condition.Price: £50?Pictures: Payment & Shipping Details: +4% Paypal and Postal £15?. Item For Sale: TD04Item Condition & Description: Leaking seals, part of the flange missing but still can be bolted up. One of the holes for the downpipe looks to be elongated. Welded for external wastegate use.Price:£20?Pictures: Payment & Shipping Details: +4% Paypal and Postal £8. Item For Sale: 4efte Cylinder headItem Condition & Description: will include all clamps and bolts, the cams are listed for sale above separately. Appears to be in good condition.Price: £80?Pictures: Payment & Shipping Details: +4% Paypal and Postal £20? Very weighty. Item For Sale: Water pump and hosing.Item Condition & Description: Used but works.Price: £10?Pictures: Payment & Shipping Details: +4% Paypal and Postal £8. Item For Sale: Standard diff.Item Condition & Description: Seems fine was removed for a cusco 1.5way.Price: Offers?Pictures: Payment & Shipping Details: +4% Paypal and Postal £8. Item For Sale:ARP head bolts.Item Condition & Description: Used but unmarked good condition can be safely reused. Picture is for visual purposes, I will dig them out and take pictures tomorrow.Price:Offers?Pictures: Payment & Shipping Details: +4% Paypal and Postal £3. Item For Sale: WEPR Braced TD04/5/VF DECATItem Condition & Description: Old and rusty could do with a wire brush and elbow grease. The brace has been fondled with and looks unsightly but does the trick. The heat wrapping is untidy and could do with being replaced.Price:£45Pictures: Payment & Shipping Details: +4% Paypal and Postal £7. Edited June 22, 2013 by TurboTobz Quote
