bigal Posted June 25, 2013 Posted June 25, 2013 alrite everyone lookin for a little help i need to find some were in gateshead were i can get a set of the little rubber washers that go under the nuts to hold the cam cover on im new around here so any help would be great Quote
StuDoc 72 Posted June 25, 2013 Posted June 25, 2013 Homebase or B&Q. You can use black rubber tap washers and then some plastic 1s on top then some normal metal 1s to round it off. Come with a nice 5 finger discount also Quote
iamlegend Posted June 25, 2013 Posted June 25, 2013 Order some of Idrees mate he will sort you out Quote
bigal Posted June 25, 2013 Author Posted June 25, 2013 Homebase or B&Q. You can use black rubber tap washers and then some plastic 1s on top then some normal metal 1s to round it off. Come with a nice 5 finger discount also nice one mate i think il get her self to drive me down to home base to get sum Quote
bigal Posted June 25, 2013 Author Posted June 25, 2013 Order some of Idrees mate he will sort you out i was lookin to try get sum today mate cheers tho these will only be a temp fix so i mite get onto him and get sum sorted Quote
StuDoc 72 Posted June 25, 2013 Posted June 25, 2013 (edited) Yeah mate originally I got mine from Dean @ RW developments. Second time round I was in your shoes and needed them there and then. I got a hold of plastic and metal washers from a local tooling shop no bother. The rubber washers proved slightly more of an issue. So went to Homebase in desperation and came across the tap washers. They come in packs of 4 though but like I said 5 finger discount ;) Edited June 25, 2013 by StuDoc 72 Quote
