brucer Posted June 25, 2013 Posted June 25, 2013 hi, what marks do the camshafts line up together with? there has been some tip-ex marks on the back of the cam gears but unsure if there correct as theres 2 different ones. thanks for any help, bruce Quote
russ78 Posted June 25, 2013 Posted June 25, 2013 (edited) line cams up with the small holes/dots on the inside of the cams and dont forget to check the oil pump mark and the cam gear 4E mark ignore the paint marks Edited June 25, 2013 by russ78 Quote
