M.B-glanza Posted June 27, 2013 Posted June 27, 2013 Right the turbo sounds asif it stops kicking in about 3 1/2 k revs and runs flat as fart. it also picks and chooses what boost it wants to run.. Sometime itll make the 0.8bar and others ita stays at around .6 And even drops off as low as .5bar.. Had some great advice from broony on this situation anyway but i thought it cant help to get more opinions before i buy a new turbo and actuator. I've checked all the pipes etc and there doesnt appear to be any leaks. Not bothered on spending the money i just dont wanna start throwing money away chasing an issue when it could be something simple. Mark, Quote
M.B-glanza Posted June 27, 2013 Author Posted June 27, 2013 (edited) Yeh posted up in the wanted secton are they a pain in the arse to fit buddy? Also if am gunna chew on with turbos etc should i be looking for a hybrid or upgrade?Should i check if the actuator is loose? Edited June 27, 2013 by M.B-glanza Quote
bigal Posted June 27, 2013 Posted June 27, 2013 yeah as said above check the actuator it cud be sticky if you have checked the all pipe work around for leaks Quote
Broony Posted June 27, 2013 Posted June 27, 2013 they are lil fiddly but easy job really!! id keep cost down atm just to fix your issue! pm micky boy hes from mboro and rebuilds turbos Quote
M.B-glanza Posted June 27, 2013 Author Posted June 27, 2013 Broony your advice on this has been great cant thank you enough. Ill order an actuator asap Quote
AdamB Posted June 27, 2013 Posted June 27, 2013 Sounds like an actuator problem if it still the stock item Quote
M.B-glanza Posted June 27, 2013 Author Posted June 27, 2013 Sounds like an actuator problem if it still the stock item Yeh its still the stock system just seems to have gotten worse over the last day or two.. Like I've said turbo seams to cut out past 3 and k im ordering a new hks actuator on monday Quote
Jim* Posted June 27, 2013 Posted June 27, 2013 I have a spare stock one if you wanted to buy a standard replacement Quote
Liam_D Posted June 28, 2013 Posted June 28, 2013 Does sound like an actuator problem. Could also be worth dropping the air filter pipe off and checking for play in the shaft. Quote
M.B-glanza Posted June 28, 2013 Author Posted June 28, 2013 (edited) I have a spare stock one if you wanted to buy a standard replacement Thanks for the offer jim if ordered a hks upgraded one. Appreciated tho matey Mark Edited June 28, 2013 by M.B-glanza Quote
M.B-glanza Posted June 28, 2013 Author Posted June 28, 2013 Does sound like an actuator problem. Could also be worth dropping the air filter pipe off and checking for play in the shaft.Yeh ill check. Should it not move at all? And if theres play im guessing a new turbo or a recon is whats also needed.. I've Got a hks actuator on the way so hopefully that should sort my actuator issue. Quote
