sosolid Posted June 28, 2013 Posted June 28, 2013 How long would lit take or how easy isit to change the valve guides on a glanza? mine blows bluey smoke if I rev it hard when stationary but wont blow any when driving it hard. Also checked camskill and there they 30 pounds and on idworkz 70. Whats the difference? Quote
akyakapotter Posted June 28, 2013 Posted June 28, 2013 Cam skills is oem ones if I was you I'd go up rated tuning developments / ziso it's a head off job bud Quote
Asad Posted June 28, 2013 Posted June 28, 2013 bad valve stem seals are usually the culprit, valve guides rarely give trouble.... Quote
sosolid Posted June 28, 2013 Author Posted June 28, 2013 when the head is taken off. how long to change them? Quote
yaristurbo Posted June 28, 2013 Posted June 28, 2013 Cams out buckets and shims compress valve spring etc... If you're not confident enough head off the to local engine/head rebuilding place Quote
Burt-21 Posted June 30, 2013 Posted June 30, 2013 Ok so I'm in the process of rebuilding my engine does any one know where to get what valves I should use thanks Quote
sosolid Posted June 30, 2013 Author Posted June 30, 2013 how much would a mechanic charge to change the valve seals and how many hours does it generally take? also is there anythin else worth changing when the head is removed? do i need a new gasket? what other parts would i need. Quote
AdamB Posted June 30, 2013 Posted June 30, 2013 Just buy a headgasket kit, comes with everything you need. Quote
