smb2011 Posted June 29, 2013 Posted June 29, 2013 Step by step the best way to change it over ?Wheels offDrive shafts outGearbox bolts to the engine off Jacket under the engine Drain oilUndo the mounts Gearbox off ? Quote
5T4R7ET N/A Posted June 29, 2013 Posted June 29, 2013 (edited) first of all make sure you got the the bits to do it, driveshafts, sandwich plate, flywheel cover, and rear mount ( LSD specific parts) use a piece of wood or something if you hold the engine using a jack, sumps are pretty soft metal couple of little thinks like starter motor off, earth strap, speedo cable and gear linkage cable come off before you start undoing gearbox bolts i would leave two bolts from the gearbox to the engine a little loose, then undo mounts and take the the last two bolts out after properly support the gearbox. prevents damage to input shaft Edited June 29, 2013 by 5T4R7ET N/A Quote
