I have looked up and found that code 52 is obviously knock sensor issue,now out of interest can the code 52 also mean that the engines experiencing knock as theres no other code to say exactly this ,so im thinking it it does apply and not only mean theres a short or issue with sensor itself ?
It's knock sensor or knock sensor signal so check all your engine bay fuses if they are ok then it's the sensor recently had this with a car I was building
Got an engine management light on but only when revved didn't get boost either so changed the knock sensor got boost but still a management light then checked the fuses and 1 had blown I can't rem Which one tho so just check them all
