my boost is set to 0.7 bar on td04 ive set my boost controller and its been fine for a few days and now it keeps boosting to 0.5 then it keeps moving up and down really fast. can hear the noise through the exhaust aswel.
its looks the same as if you hit redline and the rpm needle bounces.
Is it just the display that's doing it or is it the actual boost jumping up and down?
What controller are you using? I'd check the connections and basic stuff first.
Cheap eBay one may well be your problem for a guess? Quite possibly the solenoid is knackered and can't regulate the boost at a consistent level?
