Well I'm after some advice / recommendation really
I'm running 1.5 TRD diff and is fantastic but I think my gearbox syncs might be starting to go
Just wondered where people have sent there box's to get reconditioned and rough prices / time scales etc
I'm from Grimsby, Lincolnshire
Thanks
It's only ry got bad this week as I've had to use my car all week (which I don't normally)
I'm doing some extra training courses in over in hull... Anways
I've noticed mainly from today that its getting really hard to get into first gear
If I give it a quick shift from second into third it doesn't like that and sometimes crunches
Then even a normal shift from third to fourth it's really hard to get into gear
Also sometimes it gets stuck in gears and have to engage / disengage clutch and try again to release gear :/
Does that sound like synco's
I've ordered some updated gear selector bushes to see if the play in bushes are a problem
I've changed gearbox oil probs around 1k
Miles ago so that's fine
Clutch still seems fine;
Excedy stage 2 paddle
Thanks
Some of it sounds like syncros, I've had it before when a syncro moves slightly and causes hard to no engage
Best of having a road test in it before the box comes out, there's all ways a chance you could have a crap slave clyinder
Ohh right ok well what il do as there only £20 il just get a new slave cylinder aswell il order it now
Then il fit bushes and cylinder
Bleed it up and go from there?
I'm on a track day on Sunday just hope it doesn't go bang or jam up etc
^^ thanks for advice but if does no good il pop down and let you have a look see what you think if you don't mind?
  • 5 weeks later...
I will be putting factory lsd gearbox in mine this weekend and i will have a none lsd gearbox forsale if you wanted it
Smb2011* thanks mate but no I can't run with out LSD
Kurt grow up lol but yes il take it anyways lol
Weve already agreed a million u cant do this lmao ive tried ringing u today chand but no luck
Answer the phone man lol
