starbogt Posted August 14, 2013 Share Posted August 14, 2013 Update for all those with similar issues : - injected wd40 into the sealed cable and worked this changed the gearbox oil to ATF dexron 2 and sweet changing just need to get syncro's in box repaired Quote Link to post Share on other sites
AdamWheatley Posted August 21, 2013 Share Posted August 21, 2013 Seen this problem a few times specifically on exedy paddle clutches. Can happen when they crack/pop the springs out of the plate...that or release bearing. Take the box off and have a look. this happend on my spec clutch Quote Link to post Share on other sites
