Hey all, Ive just fitted a bleed valve just above the stock boost controller, in the hopes of raising the boost a little while still using the standard controller button on the dash, but as there are literal holes in my intake and I'm not making boost atm i thought id ask you lot whether this works or not. Will the standard boost controller just compensate for the extra bleeding? What kind of power might i expect to see with a straight pipe and short route fmic at 11 psi?
Edited by Chops
hahaha, the stock boost solenoid doesnt actively control boost its only a switch for hi and low, so the bleed valve will work
