Burt-21 Posted July 8, 2013 Posted July 8, 2013 Hi can any one tell me what they do and if I should have oil going through it to my inlet manifold thanks Quote
Chris Green Posted July 8, 2013 Posted July 8, 2013 Hi can any one tell me what they do and if I should have oil going through it to my inlet manifold thanks PCV valve, and yes it is a crank case breather that runs to the intake mani. Quote
Burt-21 Posted July 8, 2013 Author Posted July 8, 2013 Ok so the problem I have is blue smoke and I have herd this could be 1 of the problems and wasn't to sure if there was meant to be oil coming to the inlet Quote
AdamB Posted July 8, 2013 Posted July 8, 2013 No oil shouldn't be going to the intake. Its only oil vapour that gets plumbed back into the intake. The PCV can be a problem yes. Quote
Burt-21 Posted July 8, 2013 Author Posted July 8, 2013 So any ideas to why I have oil going thought it could it need replacing Quote
Danza V Posted July 10, 2013 Posted July 10, 2013 The little flap inside is probably bust and stuck open. Quote
Burt-21 Posted July 10, 2013 Author Posted July 10, 2013 I have blown through the valve and it opens and closes Quote
Danza V Posted July 12, 2013 Posted July 12, 2013 Could be a bit sticky then. Toyota say they should be replaced ever 30-40k if I'm right anyway. Quote
