Compression results
Efi removed
King lead removed
All plugs removed
Engine warm
Full throttle i had somebody crank till it builds much compression as can and put foot down and i also push throttle pully down
Test results
Cylinder 1 : 170psi
Cylinder 2 : 180psi
Cylinder 3: 170psi
Cylinder 4 : 170psi
Also for cylinder 2 i didnt push throttle pully all way down but was pressed from inside car
Is this okay
Okay as when i took oil cap off and gives out smoke/steam and it goes away.
But when i rev it, it does slightly give smoke unless its steam.
But results are okay so.
Only thing im thinking is what if on cylinder 2 if i held throttle pully down aswell it may be like 190 or something?
I didnt hold it down on cylinder 2 , only accelerator was pressed from inside
And for cylinder 1 it was 160 psi with accelerator down, but i did again with the throttle pully all way down it went to 170
around 180 is best u will ever get from these engines standard.checked mine and got these results a month ago.
years ago when i bent a conrod one cylinder went down to 90 odd i think.i made a banana of the rod.
Edited by mikey4410
Still got a PCV mate? Sounds like this as it is only open under vacuum and closes under boost. So if your getting excessive vapour come out the oil cap it would indicate your getting excessive crank case pressure.
No adam i have no pcv , just a race spec rocker and the both pipes of the race spec rocker are venting.
